CAT 910 need governor assembly
Bser
11-30-2007 15:11:29
My Cat 910 has been down over a year.After the mechanic left parts in the weather,i need a governor assembly that Cat doesn't service anymore. Does anyone have a good used assembly? It is a 3204 engine.Any ideas on a source?I really need this up and running, a BIG THANKS in advance.
VaTom
12-04-2007 12:13:05
 Re: CAT 910 need governor assembly in reply to Bser, 11-30-2007 15:11:29
If that's similar to the governor on my 944, was very simple to rebuild. Cat had the 1 shaft I needed. Due to a broken bolt, had to cut it in half to get it out.
Nothing in there that would be difficult to fabricate if Cat couldn't come up with the part.
From what I found in mine, you'd probably be better off rebuilding what you have. That way everything's right and you don't go back in any time soon.
Bob/Ont
11-30-2007 18:31:03
BSER, how apart is it? Could you post a pic. I don't think all is lost. You might be able to find a real mechanic that can save it.
Later Bob
