TD-9 Control levers and pedals needed
Dan Woodall
11-30-2007 19:54:01
I am restoring a TD-9 that had been converted into an "orchard" model, all of the levers and pedals had been cut and rearranged. I"m wanting to restore it"s original configuration. I"d like to fing both L & R brake pedals, L & R Steering Clutch levers, Main clutch lever, Gas/Diesel lever, and Fuel lever. Any of these items would be a big help. Thanks, Dan.
dlplost
12-01-2007 10:45:10
 Re: TD-9 Control levers and pedals needed in reply to Dan Woodall, 11-30-2007 19:54:01
The best source for ALL things IH can be found at REDPOWERMAGAZINE, Everything else is right here at YTMAG.
Look under "Forums", "construction equipment"
old timer in ohio
11-30-2007 23:54:29
Hey there Tom;
Yes I've picked up the Bible (again),I guess all I can do is plead ignorance.Because I never took the time to listen,to The Good Lord when he spoke to me.
Now as I look back all that I see,is all the mistakes,I've made!!! Bob God Bless
P.S. I'm 75
Tractor Tom
11-30-2007 22:48:50
Dan, someone may come along here and bail you out with parts, like Hector Gemme (sorry Hector if I misspelled your name). The mother lode for all things about IH crawlers can be found at the construction equipment forum at Redpower.com. Other sources for your parts are FP Smith (Calif) and Crawler Heaven (Idaho). There is another in NY but the name escapes me. Try the Redpower forum. Good luck.
Tractor Tom
11-30-2007 23:06:01
 Re: TD-9 Control levers and pedals needed in reply to Tractor Tom, 11-30-2007 22:48:50
NOW I remember, Crawler Heaven in in New York and General Gear is in Idaho. There is going to be a quiz on this later..... ..... .....
Speaking of tests, a friend of mine said he thought it was interesting that so many elderly people really take up the bible when they get up in years. He was wondering isn't that kinda like cramming for finals? :-) Better late than never! No insult intended to anyone. Good luck.
