IH 2400 Loader/backhoe
danielm
12-01-2007 14:46:44
I"m looking to purchase this tractor to use around the farm. Seller says the backhoe boom failed to swing last time he tried it. Looking at the parts drawing I see it is a rack and pinion type mech. The rack has a piston on each end for the left and right hyd cylinders. I was told these parts are NLA. The seller seems to think its a problem with the operating lever spool. Is there an easy way to check what might be the problem without tearing into it? I belive I will pass if its a rack and pinion issue. Also, this tractor has the forward/reverse lever on the dash. It looks as though it operates a valve on top of the trans. Are these shuttle shifts problematic? I took a good battery (she's been sitting for over a yr) and found a bad starter. I am having to get the starter rebuilt to check it out. So, I"m in it for about $50 so far. I"m finding little info about this machine.
Anyone familiar with this one?
danielm
12-06-2007 09:03:07
 Re: IH 2400 Loader/backhoe in reply to danielm, 12-01-2007 14:46:44
Anyone? Is the 2400 a rare one? I'm digging up very little info about it online.
