BIODiesel ?
U9 U9 CAT
12-01-2007 23:10:11
Well how about this bio Diesel, cooking oil and lye sounds too good.
Any coments out there?
Lee Bradley
12-04-2007 15:51:31
 Re: BIODiesel ? in reply to U9 U9 CAT, 12-01-2007 23:10:11
For more information check http://www.frybrid.com/test.htm
yello fello
12-03-2007 18:39:08
U9 U9 CAT said: i know a guy who was running the converted cooking oil in his truck with great results. but... he was stopped and had a fuel check at one of them roadside d.o.t. truck checks. he got the same fine as you would get for running farm fuel! the goverment lost a few dollars tax third party image(reply to post at 18:06:17 12/02/07)
kyhayman
12-02-2007 11:45:08
The diesel repair shops are full of all kinds of horror stories about it. Main problems I have been hearing are people who are not filtering it adequately, or are ignoring the differences in chemistry.
I run a B10 blend in the winter and a B 20 in the summer. What I've seen so far is less smoke, better performance, cleaner oil analysis, and lower costs. On the down side, my repair bills for injecter fouling and related engine/head damage are WAY up (just got done putting 3 grand into my pickup). It is more oily and for those engines that were made for LSD I think the extra sticky and tacky factor of the bio diesel is making more deposits. For 3 grand I could have bought a lot of dino diesel.
( sonny )
12-02-2007 11:28:33
bio-fuel will clean the fuel system,storage tank,fuel lines,fuel tank,.you will experience fuel filters stopping up until the system is clean,then
operation should return to normal,you should see more power,less smoke,on less fuel.
i use cat, cummins, & john deere,engines,i use mostly 10 or 20% blend,i have used a half & half
mix,with no problems.i don't know about cold weather as i do treat for cold weather. good luck,maybe someone will comment. sonny
JV3CII
12-02-2007 09:33:13
It"s worth browsing round the forum at the link below for a little extra info on making and running Biodiesel. There are several different approaches to the process.
I don"t have room to hide a DIY processor but I"ve successfully trialed both my pickup and the car on commercially made B100.
bjb in Ne
12-02-2007 09:01:59
The chemistry works, but the actual mechanism is not described completely accurately on websites.
JCSinGA
12-02-2007 05:38:10
It sounds great but I cant see where all the used cooking oil or new oil for that matter is going to come from to feed the U.S. need for diesel fuel, mabye as a supplement? I do think it's a step in the right direction 'tho, but it's far from the solution.
Not enough corn to make liquor for Ethanol production either. Brazil does it with sugarcane I think.
U9 U9 CAT
12-02-2007 09:06:17
 Re: BIODiesel ? in reply to JCSinGA, 12-02-2007 05:38:10
I wonder what are the byproducts of making it, what do you have left over? I have access to cooking oil, 150gal a week. I think I'm going to try it out I keep you posted
JDknut
12-05-2007 12:14:11
 Re: BIODiesel ? in reply to U9 U9 CAT, 12-02-2007 09:06:17
The by product is a dark brown liquid (at room temps) mixture of unreacted methanol, glycerin, fatty acids and soaps from the biodiesel chemical reaction. It is supposed to be pretty good for use as a heavy duty clean-up soap (to clean up after wrenching on greasy tractor parts, for example). About 20% by volume of this by-product is produced. The exact amount depends on the quality of the original feedstock. Used cooking oils with high free fatty acids give the most residue. This residue is mainly bio degradable. Larger firms re-distill it to reclaim the methanol as it is expensive.
