TL12 allis wheel load, won't stay running 262 gas
DVH
12-02-2007 15:54:29
Was running good, except under load did some spitting and sputting,now it starts and idles but as soon as you give it some throttle it dies,sounds like it is not getting gas,there is gas to the carb, have new line from gas tank, new filter and bowl. Is my carb bad? Any ideas would be appreciated. Thank you. Need to get his figured out as it is blocking part of my driveway, and can't move it.
chuck craig in SUNNY SOCA
12-03-2007 18:42:08
 Re: TL12 allis wheel load, won't stay running 262 gas in reply to DVH, 12-02-2007 15:54:29
If your fuel is good checkyour point gap. our loader had a similiar problem and it turned out to be too wide. JAT CC
tmadsen
12-02-2007 18:45:31
some of the older units hade a bad habit of getting parshal blockage in the fuel tank at the sediment bulb. pull the fuel line off carb and make shure there is a nice steady steam of fuel.Some times they run grate at start up then run and die.two minutes later fuel builds up runs great then dies.
