IH TD-340 hydraulic pump failure?
trees
12-11-2007 08:53:57
I have a very slow moving dozer blade.
Where is the hydraulic filter located? How do you get to it? It looks like the 6-way blade and tracks have to be removed to get to the pump.
trees
12-14-2007 15:13:17
 Re: IH TD-340 hydraulic pump failure? in reply to trees, 12-11-2007 08:53:57
Thanks. Found it cleaned it and it works great.
Charlie
12-11-2007 14:06:08
Its on the right side of the clutch housing, opposite where the typical pump is located, and its the dominant reason for slow hydraulics in this machine. See the extensive discussion on the Delphi Forums T340 web site. You take off a cover plate that has somewhere around 10 machine screws holding it on, and the filter and screen are there. No need to drain down the oil first. there are tow kinds of filters in use on this machine.
