JD450B tranny problem
hoonboy
12-11-2007 17:55:22
I rehabbed a 450B that has been working pretty good for the last 3 months. Has a 6-way blade and was pushing pretty strong in 1st and 2nd. It has been getting progressively weaker in all gears and now will barely move. I checked the clutch adjustment as prescribed by the manual. No joy. I then pulled the accumulator plug and checked the shims. I added 2 shims but lost the crisp shifting of the 4 gears. It still trys to pull but the distinct shifting ceased. So I removed the extra shims back to it's default but did not regain the shifting quality I had before. Also it made no diffrence in the pushing power. It acts like it wants to go but just can't grab hold(kinda like me some days). I think it is an oil pressure issue. Should I look at the needle valve adjustment next or replace the in transmiision filter and clean the screen first. I think the trans is still good but needs adjusting and or service. It was working great. This machine had not been serviced properly and sat up for awhile before I got it.
Roy Suomi
12-11-2007 18:55:32
 Re: JD450B tranny problem in reply to hoonboy, 12-11-2007 17:55:22
It's just me again...Look at the HLR pressure adjustments with the gauge put into the HLR pressure tap..If you don't have the pressure set right , and the speed of shift set right it just flat won't work right....
Roy Suomi
12-11-2007 18:52:41
Hey Hoon....Go to the archives and type in JD 450 transmission adjustment..I'll bet you find gobs of usefull information there..This'll save me from going thru this again..I've put many adjustment procedures into this forum..If you don't have any luck with the information there , I'm sure myself and learned others that are regulars here will pipe in and help..Good luck..R.S.
hoonboy
12-12-2007 03:13:56
 Re: JD450B tranny problem in reply to Roy Suomi, 12-11-2007 18:52:41
I'll check out the archives. The pressure test should tell the tale. Thanks Roy.
