OIL LEAKING TIMING GEAR HOUSING
Joes13
12-15-2007 18:21:55
My Dozer D6 9U is leaking oil from the timing gear housing of the right side of the enginee where the alternator goes.
I have already removed the alternator and I can not see where is this oli coming from, I just know it is coming from the inside of the housing.
Someone know how can I stop the leaking?
Joe
AJ.
12-19-2007 14:28:28
 Re: OIL LEAKING TIMING GEAR HOUSING in reply to Joes13, 12-15-2007 18:21:55
The OEM charging system would have been a gear driven generator,there would have been a gasket between the generator flange and the housing,I seem to remember a charging kit that included an extention for the housing,ie you removed a plate and bolted on a housing to carry the generator,there was a gasket there too,as said in the other post clean and run to find the source.
AJ
RAB
12-16-2007 01:58:49
You could replace the whole engine!! Find where the leak is coming from, first. Once you know that, the remedy may be more obvious, or at least narrowed down a little more.
Cleaning, followed by observation, after a short amount of running/leakage, is the way to go at this point of the investigation.
RAB
