JD 450 Diesel Engine
Tweeter
12-22-2007 18:38:50
How much does the motor from my 1966 straight JD 450 weigh?
jdemaris
12-23-2007 07:45:06
 Re: JD 450 Diesel Engine in reply to Tweeter, 12-22-2007 18:38:50
Well, I guess I don't have a clue. I'll guess at 1100 lbs. with all stuff attached when it's pulled from a 450. It's an extra-heavy cast block since the block gets no front support. And, when taking it out, it comes with radiator and pump cradle attached, etc.
A Mitsubish 211 cube four-cylinder diesel weighs 1200 lbs. with all accessories attached.
A four-cylinder Isuzu 236 cube, 3.9 diesel with some aluminum weighs 800 lbs. without accessories.
A four cylinder 236 cube Cummins 3.9 diesel weighs 725 lbs. without accessories and close to 900 lbs. with.
Considering the Deere engine is about the same size and casting-thickness as the Cummins 3.9, it must weigh close to the same. Around 750 lbs plus the extra 200-300 lbs. of stuff attached to it.
Roy Suomi
12-23-2007 04:35:32
Man....Thats a question I've never run into..I'll say this , It's a lot heavier than it looks..Maybe Jonathan or Jdemaris have a clue...A cherry picker[2000 lb cap.] will pick it as long as the front legs go around or in between the tracks..You're gonna have to keep it tucked in short..And picking over the side is out of the question. I prefer my service truck crane or a gantry to pull that motor..I pull them complete radiator and all..
