D47U Generator
Fin
12-26-2007 06:01:14
I have a 1952 D47U cat dozer. I am trying to convert the generator from a 6 volt to 12 volt. I have changed the windings on a 1960 70D grader gen. with 2 brushes and it works fine. The D4 has 3 brushes and the output is very earatic, jumping from 18 volts to 3 volts and anywhere inbetween. I have burned up several voltage regulators. The generator is gear driven so installing a alternator is going to be dificult. Can anyone help??? Thhanks
bob plumadore
12-27-2007 18:44:24
 Re: D47U Generator in reply to Fin, 12-26-2007 06:01:14
you can add an extra sheiv to your crankshaft pully and fabricate a mount. eith leave the generator in the housing or replace it with a plate. I have done this several times.
Fin
12-29-2007 12:48:19
 Re: D47U Generator in reply to bob plumadore, 12-27-2007 18:44:24
Thanks for the reply. I might end up doing something like that if I can't figure it out. Thanks again.
