jd 350 injector trouble
gto mike
12-28-2007 15:05:24
i let my 350 crawler run low on fuel and it pulled a bunch of trash into my injectors.seems as if it wasent getting any fuel,but a friend told me to check the top of the injector and see if their is any fuel returning to tank,and their was none,i loosend the adjustment while it was running and after a minute or so it started to flow. i was wondering if anybody could tell me the proper way to adjust these. mike
MN Scott
12-28-2007 16:03:27
 Re: jd 350 injector trouble in reply to gto mike, 12-28-2007 15:05:24
Your fuel filter should have stopped any dirt before it even reached the injector pump let alone the injectors. If your talking about the injectors in the head they have to be set on a pressure tester while out of the engine.
gto mike
12-28-2007 19:51:09
 Re: jd 350 injector trouble in reply to MN Scott, 12-28-2007 16:03:27
thanks mn scott.
