Case 580 Super K Cab Heater
Larry M/Keweena
01-03-2008 08:56:53
Where is the cab heater located in a 1992 Case 580 Super K backhoe? Cousin has one and asked me to post.
AJ.
01-03-2008 09:50:26
 Re: Case 580 Super K Cab Heater in reply to Larry M/Keweenaw Bay, MI, 01-03-2008 08:56:53
The heater unit is above the roof lining to the front,there are some vents in the lining the unit is behind them,there are on off valves on the lines on the engine,some machines have two and some one,both are turned anti clock for on,there is another regulator valve inside the cab on the console to regulate the heat,the fuse for the heater is the bottom middle in the box.
AJ
01-08-2008 08:42:50
 Re: Case 580 Super K Cab Heater in reply to AJ., 01-03-2008 09:50:26
Thanks for the info!
