POSITION OF THE GEAR SHIFT
joes13
01-05-2008 07:34:30
Thank you for your help, I have another question when must be used each speed on the Dozer D69U? when to use the 1st, 2nd,...5th?
If I want to move earth it must be on 1st speed? My question is because every time I want to change the speed the dozer stops to be able to change another speeds, so what is every speed used for?
Regards
135 Fan
01-05-2008 12:13:58
 Re: POSITION OF THE GEAR SHIFT in reply to joes13, 01-05-2008 07:34:30
It depends what you are doing. Heavy digging might require 1st gear where spreading topsoil could be done in 3rd. As long as the dozer keeps moving, you don't always have to use 1st gear. Same as a tractor. Dave
