AC TD 15 A Little Info Please
uncle
01-05-2008 16:23:20
I am looking at a TD 15 on Ebay. It's not too far from me.
I am looking to just have it around the farm for occasional use on the road and pond dam.
Can someone tell me a little about them?
I need to know the weight also to see if I can haul it.
Brian
Bob Blue
01-05-2008 17:27:14
 Re: AC TD 15 A Little Info Please in reply to uncle, 01-05-2008 16:23:20
That doesn't look like my old Td 15 !51 series. When sitting in the seat, the 15 air filter system is located on the back right hand side of the engine compartment and the stack comes thru the hood on the back RH side of the sheet metal. This one is in the center of the hood. On the photo of the right hand side, you cannot see the oil bath compartment of the air filter. The hyd rod control system runs along the top of the engine frame metal a little higher than the tracks on the 15. This one is up high by the engine sheet metal. The 15s had a convental hyd blade lift system, not the Bur-eire system. Take a look at it. Serial plate will be on the middle area of the right hand side of the dash. If it is a 14, around 22,000lbs, a 15 about 30,000lbs. If it starts and runs you might get some use out of it, if it blows, can part it out and sell the steel. Take a look at it and let us know. Check this site every day and I will look for your findings. Bob Ohio TD15 and AC HD21A dozers
uncle
01-05-2008 18:54:38
 Re: AC TD 15 A Little Info Please in reply to Bob Blue, 01-05-2008 17:27:14
You are right, It was an International not the AC.
I will take a look at it and see if it's the dual fuel set up.
Brian
shade tree cat
01-05-2008 17:04:02
brian are you talking about a td 15 international? if it starts on gas and switches over to diesel after it starts . my 2 cents worth .dont waste your money. they are notorius for cracking heads. believe me i know i owned one.
Bob Blue
01-06-2008 14:27:24
 Re: AC TD 15 A Little Info Please in reply to shade tree cat, 01-05-2008 17:04:02
Brian: Was over on the other side of the farm and looked at the TD15. The air filter system is on the left side of the engine several feet from the radiator. The air tube comes straight up from the oil cannister unit thru the foward left side of the hood sheet metal. Looking at the left side of the engine compartment it is towards the front and is large. Bob
