My old 3cx 1988 old gal wont start
Jayjayd
01-10-2008 14:57:11
my old girl wont start, i have changed the filters, and got diesel to the pump (thinking my blocks the perkins with CAV pump on the left hand side as looking from the cab)... rotary! i cant get diesel up to the injectors, filled tank up to the top with fresh clean diesel got diesel out of the filter bowl... why is she having such a pull?!?! grumpy ol cow!!! maybe 1 day shel get up off her arse and do some work for a change... "not the missis the JCB im on about!!!"
AJ.
01-11-2008 14:35:10
 Re: My old 3cx 1988 old gal wont start in reply to Jayjayd, 01-10-2008 14:57:11
If you got a manual stop either the pump/engine was changed or the machine is earlier than 88 does it have electric F/R shift,the early machines had a pull stop cable,it does not make any differ same 4.236 Perkins,that CAV pump likes clean fuel,good workhorse,keep the rad and cooler clean,sorry I can"t translate this into Esperanto.
Good digging
AJ
AJ.
01-11-2008 00:20:23
A 1988 machine will have an electric shut off so make sure that the shut off solenoid is getting power when the key switch is on,put your fingers on it and have someone turn the key on and off,you should feel it jump,if that checks ok starting at the fuel priming pump take the top off and clean the pump body and gauze filter,there should be a good flow of fuel there so you need to put a hose clamp on the line to stem the flow and take it off when you have the pump cleaned,open the bleeders on the filters and the two on the injector pump,prime the pump till clear fuel comes from the filters and close the bleeders,prime till clear fuel comes from the bottom bleeder and close it and then the top one last,open all four injector pipes a couple of turns each,on full throttle spin the engine over on the starter till fuel starts to spurt out the unions,then tighten them up and the engine should start,you need the battery in good condition.
AJ
Jayjayd
01-11-2008 14:13:57
 Re: My old 3cx 1988 old gal wont start in reply to AJ., 01-11-2008 00:20:23
cheers m8, u sused my problem AJ, thnx so much... i just dont know why she did that, the problem was the top bleed nipple was hidden by the throtle body, and for some reason the machine is fitted with the push pull start stop...not selonoid! oh well pretty mad...and to start it its pulled out!!! so the toggle is sliding towards the back of the pump and not the gears! total NUTS! well im plonkin my lil 8yo son on the 3cx, im not letting him on the 40tonne 360's yet!!!
