tom spivak
WHISKEY BENT
01-10-2008 18:35:23
TOM, SORRY TOOK SO LONG TO GET BACK. TAG INSIDE CAB SAYS 75-40. ITS 4 WHEEL DRIVE HAS SHIFTER FOR 4 WHEEL OR 2 WHEEL, REAR AXLE STEERS, HAS 6 CYL GAS I THINK WAKASHAW? STEERING COLUME HAS 2 LEVERS ONE FORWARD/REVERSE HAVENT FIGURED OUT WHAT OTHER ONE DOES SOMETHING WITH SHIFTING. NEXT TO THE 2 WD/4 WD SHIFTER IS A HI/LOW SHIFT. THANKS FOR ANY HELP!
Thomas R. Spivak
01-11-2008 09:20:59
 Re: tom spivak in reply to WHISKEY BENT, 01-10-2008 18:35:23
On the column the short lever is fwd, rev., neu.
The other is high and low and can be shifted on the go within reason.
These machines are rated at 8000 lb.s lifting depending on equipment.
There should be a brass tag on the front of the transmission down below.
If it says Clarke, and it should, parts are readily available from a source here in Ontario, Can.
Watch out for do hard pushing when turning sharp as it can wreck the u joints on the back wheels.
I will send you some more info if you like, maybe you can send me a picture? I have a complete operater, parts and maintainance cd as well.
