ENGINE STUCK D4
joes13
01-12-2008 21:42:43
I have a dozer D4, the dozer was about 8 year with out use, now the enginee is stuck, what can I do to to release the pistons?
I have tried to run the starter but nothing happened.
Joe
37 chief
01-15-2008 22:08:38
 Re: ENGINE STUCK D4 in reply to joes13, 01-12-2008 21:42:43
The first thing I would do is pull the oil drain plug. If water comes out you have major rust in the cylinders. Stan
Andy Motteberg
01-14-2008 21:56:20
Try putting PB Blaster/or Brake Fluid in the cylinders. Let them soak for a while. If it does not come loose still, you may need to take the motor apart and get it free'd up.
Lanse
01-14-2008 17:58:10
 H I !!! in reply to joes13, 01-12-2008 21:42:43
I would consult OLD, hes an expert here!!
joes13
01-13-2008 22:26:54
Thank you for the support, I will try with the 50-50 ATF and diesel, I`ll let you know after a week if it works
Joe
john_bud
01-13-2008 18:48:11
Can you gain access to the cylinders by removing a glow plug or injector? If so, add 2-3 oz of 50-50 atf and diesel. Do that every day for a week. With the injectors out, try and turn it over after a week. Try again a week later. Also, change the oil. It may have a crank full of water. I pulled the drain on an old tractor and got 5 gal of water before any oil. That one had issues...
If it won't break free after 2 or 3 weeks, then you probably have to take it apart. If water got in the cylinder, then there may be a layer of mud in there and rust like you can't imagine.
jb
Bob Plumadore
01-13-2008 13:32:50
Steve is right.with a little bit of luck you will get by with replacingthe valves , valve guites and seats in the head. You are probably going to have to replace at least 2 of the pistons & liners.I would go ahead and do all 4 at the same time.
bob plumadore
01-13-2008 05:19:44
why is it stuck? Did it sit out side with the exhaust uncovered? whan SN D4?
joes13
01-13-2008 08:51:44
 Re: ENGINE STUCK D4 in reply to bob plumadore, 01-13-2008 05:19:44
Yes, the dozer was sit outside with the exhaust uncovered, I mean it had only the exhaust manifold,
I have tried to move the wheel of the clutch and the belt of the fan, but it is too hard.
What can I do?
steve in mtaville ca
01-13-2008 09:32:05
 Re: ENGINE STUCK D4 in reply to joes13, 01-13-2008 08:51:44
tear it down and do it right, never try to force a stuck motor with a head on it, it may have frozen valves and you'll bend pushrods
