955L Track Adjustment
Steve Byrum
01-13-2008 16:56:39
My 955L right track will keeps sagging after I grease it up to specs. I see NO grease leaking from either the grease fitting or the tensioner adjuster bolt, or the housing below. I thought this was a closed system, so once I added grease to get the track adjusted, it should hold in place or I'd see grease exiting from somewhere? Has anybody else had this problem? The left side is working/holding fine.
Lynn Davis
02-01-2008 10:16:26
 Re: 955L Track Adjustment in reply to Steve Byrum, 01-13-2008 16:56:39
Yeah, like Bob says it comes out the other end from where you are looking, irritated me to no end knowing it was leaking and couldnot find it.
Bob/Ont
01-13-2008 17:04:00
It's leaking into the spring pilot behind the cylinder. Need to replace seal on piston.
Later Bob
