Changing D9G brake bands
tcumming
01-16-2008 22:53:56
The repair manual for my D9G A11557 shows the entire clutch assembly being removed in the same manual section as removing the brake bands. I thought the bands could be pulled up and around the clutch without removing the clutch. Since the clutch weights about 300lbs, and is held in with 16 bolts most of which are inaccessible, I'd rather not remove the clutch if possible.
Thanx, tomc
Bob/Ont
01-17-2008 06:12:16
 Re: Changing D9G brake bands in reply to tcumming, 01-16-2008 22:53:56
You need to lift out clutch, band is solid and has to be slid off the side. You need a hoist to lift with and use a jack to turn the track so you can get all bolts out.
Later Bob
