rear main oil leak/cat d6
Lauro Salinas
01-20-2008 13:10:13
My 1959 cat d6 leaks a lot of motor oil into the clutch(wet clutch), I am told that it does not take an oil seal, can some one tell me how to correct the problem.
thanks
AJ.
01-21-2008 06:06:20
 Re: rear main oil leak/cat d6 in reply to Lauro Salinas, 01-20-2008 13:10:13
That engine does not have a conventional back seal it has grooves on the shaft that throws the oil away from the flywheel end,if the bearing is worn oil can leak into the clutch.
AJ
Lauro Salinas
01-22-2008 10:06:45
 Re: rear main oil leak/cat d6 in reply to AJ., 01-21-2008 06:06:20
thanks AJ for the information.
hector gemme
01-20-2008 13:45:58
You should't have oil coming from big motor ,no seal and no gasket being belhousing, the oil should came from the poney or cover valve or the seal from compression shaft.
Lauro Salinas
01-20-2008 13:52:28
 Re: rear main oil leak/cat d6 in reply to hector gemme, 01-20-2008 13:45:58
hector thanks, the pony is sealed off no water or oil in pony tractor was converted to electric start.
hector gemme
01-20-2008 14:34:09
 Re: rear main oil leak/cat d6 in reply to Lauro Salinas, 01-20-2008 13:52:28
The oil should came by the transmission shaft or some d318 crankshaft had in center flange a hole with tread and plug am not sure they were use for motor grader.
Lauro Salinas
01-20-2008 15:22:29
 Re: rear main oil leak/cat d6 in reply to hector gemme, 01-20-2008 14:34:09
thanks, we'll look into that.
