How to remove Front Blade
owen
01-21-2002 07:20:33
I got a JDMC with a front blade that mounts on the outside of the tracks. It connects to square shaft that is connected to the hydraulic cylinder unit. Can someone tell me the steps to remove it. I don not know what brand it is. I can see a couple of bolts that must be removed, but it doesn't look like I can get the bracket off from the square shaft? It also has a plate that is located below and behind the square shaft. I do not know if it locks the unit to the square shaft or not.
Thanks in advance
Owen
