george md
01-26-2008 18:38:31
Re: Case 750 dozer in reply to jdemaris, 01-26-2008 09:50:29
Jd, 750 uses the same roller and rails as 800,1000, 850 ,& 1150 , the number of links will be less. It does have the 267 engine -- 4 cyl, 4 1/8 bore , 5 inch stroke , and in 730 farm tractor it's 65 gross hp ,56 pto & 52 drawbar ,I have a 730 second series high profile & eagle hitch. In 1967 I almost bought a 750 , but while looking at it I saw the 1000 c and bought it, still have it. 267 is a tough engine and not hard on fuel, rated about 2.5 per hr and mine on a big disc with spring tooth will use near 3 gal. 750 trans is a 6 clutch power shift trans, quite similar to 450 but bigger. Shuttle F/R one lever , high and low each track , 2 levers. brakes are double disc -center plate expanding and are on the out side of the trans.Steering is done with either range levers or with brake which drops the clutch of which ever brake you push or push both to stop . If you get it , I have parts book on CD. george
