Ripper for D4
CAL (KS)
01-30-2008 06:21:14
im interested in mounting some kind of ripper to a D4 5T model, so 45-47. I plan on using it for ripping in ground where trees have been removed. No redwoods or anything mostly pushed out hedge. Im guessing that the OE tool bar is like finding a needle in a haystack. Is fabricating one to mount on the rear going to tear up the rear houising. I was thinking of incorporating it to also pull from the drawbar pull point underneath not just the rear casing. what do you guys think?
also how many shanks and what kinda of depth could i expect from this machine. Is one or two shanks @ 12 inches to much to expect?
jm.watkins
02-04-2008 11:08:23
 Re: Ripper for D4 in reply to CAL (KS), 01-30-2008 06:21:14
Located in Tennessee can get photos if needed. 245 mi south of St Louis Mo if that helps any.
Complete with 3 shanks and hydraulic cylinder.
jm.watkins
01-31-2008 11:58:52
old Magnet you are probably riht they fasten to something under the tractor maybe the drawbar pin or something. I did not take the unit off just know it cam from a 1956 D4d Have no idea what the sn of the unit was//I know the hyd were a little funny they plumed in behind the blade valve.
CAL (KS)
01-31-2008 18:18:42
 Re: Ripper for D4 in reply to jm.watkins, 01-31-2008 11:58:52
jm. watkins im interested in discussing this unit. Probably out of the question unless its located in the midwest but id still like info on it click send email
jm.watkins
01-30-2008 14:23:19
have the d4 ripper that would mount to rear of machine and has two bars that go up under the machine and clamp to the dead axel. Complete with 3 shanks. No crazy about putting my phone number or e mail on here so put something on where i can call you or e mail and we will discuss this unit.
CAL (KS)
01-31-2008 06:22:39
 Re: Ripper for D4 in reply to jm.watkins, 01-30-2008 14:23:19
i dont see how that would work on this type of machine but email is open.
Old Magnet
01-31-2008 14:47:58
 Re: Ripper for D4 in reply to CAL (KS), 01-31-2008 06:22:39
Cal(KS)
The later D4 "U" model transmission case (1956) is the same bolting as your 5T. Sounds like a correct unit. Be interested myself if it was in California or at least closer than what I suspect.
Old Magnet
01-30-2008 15:57:05
I'm curious as to how that works as the dead axle is not exposed on the D4. Is it off a different machine? Thanks
Old Magnet
01-30-2008 09:22:24
Over the life of the D4 there has been both scarifiers and rippers factory mounted.
The latest were the Cat #4, 951, 955 Model 58D1-up and 87H1-up and had five ripper pockets with teeth about 20 - 21 inches long (less mounting for projection)
The earlier HT4 (loader) had a seven pocket scarifier option with teeth about 14 - 16 inches long (less mounting for projection.
All had provision to tie the mounting frame to the draw bar mount under the transmission case.
