case 350 crawler dozer
alesv
02-10-2008 20:16:53
Never done brakes in a dozer. Whats involved. I was told the whole rear end has to remove to get to them. Does anyone know where i can get a sept by step instruction from? Thanks
Vinnie
alesv
02-15-2008 23:39:27
 Re: case 350 crawler dozer in reply to alesv, 02-10-2008 20:16:53
I took everthing apart and it appears that the brake were good. There was about 1/4 inch of pad left. It looks like whoever put the brakes in didn't ajust them right inside. We ajusted them and the machine has alot more pedal then before.
Thank everone for all you info.
Vinnie
alesv
02-13-2008 12:11:25
Thanks everyone once I get the new pads or relined I'll be replacing them.
jdemaris
02-11-2008 05:27:14
Doesn't the Case 350 have the old Clark transaxle, same as used in the Cletracs and Terratracs? Just to differential brake banks that come out the back pretty easy.
Mark in Monroe
02-10-2008 22:47:55
Hey alesv, I have done the brake bands on my 350. Rear cover is removed and the bands come right out the back. Be sure to use the right oil.
alesv
02-11-2008 07:37:59
 Re: case 350 crawler dozer in reply to Mark in Monroe, 02-10-2008 22:47:55
What kind of gear oil and how much do I put in?
Thanks for the info
Vinnie
CHinNY
02-11-2008 08:05:04
 Re: case 350 crawler dozer in reply to alesv, 02-11-2008 07:37:59
GL 1 oil i sell shop manual for that machine also remember to take the drawbar support off you can roll the bands right out much easier without bending them up. email me for my web site
alesv
02-11-2008 14:14:47
 Re: case 350 crawler dozer in reply to CHinNY, 02-11-2008 08:05:04
The rear cover that needs to be remove. It is the one behind the winch?
CHinNY
02-12-2008 06:08:39
 Re: case 350 crawler dozer in reply to alesv, 02-11-2008 14:14:47
Yes you must take winch off, Also i sell shop manuals for that machine.
