Case580K Erratic gauges
L. Cruise
02-11-2008 08:07:20
1989 580K. Tach., Alternator gauges operate erratically. Sometimes work, sometimes don't. Where should I look first?
Thanks!
AJ.
02-11-2008 12:22:44
 Re: Case580K Erratic gauges in reply to L. Cruise, 02-11-2008 08:07:20
Check that the wiring loom that runs along inside the right frame member from the alternator via the starter to the console on the side, I"v had the loom grounding along parts ot that route,the voltage regulator would be the next thing to go for,get a new one and put it on,disconnect the battery while doing it,only two screws to undo and the reg and brushes lifts off.
AJ
L. Cruise
02-11-2008 20:13:29
 Re: Case580K Erratic gauges in reply to AJ., 02-11-2008 12:22:44
Thanks, AJ. I'll check for grounds and try the regulator if no grounds found.
L. Cruise
