JD 350 crawler with loose shift lever
BDCZ
02-16-2008 15:51:01
If there is anyone out there who can tell me what's usually wrong when the shifter on my type dozer is very loose. It will shift into any gear once you find it and it will stay in gear it's just that the shift lever is very sloppy making it hard to find each gear. I have the 350 gas engine with 4 speed tranny and hydraulic reverser.
BDCZ
02-22-2008 21:52:49
 Re: JD 350 crawler with loose shift lever in reply to BDCZ, 02-16-2008 15:51:01
OP, yes I have the shifter guide attached under the seat. I can't believe and hope that I don't have a tranny shaft that loose since the tranny works fine once in gear. I'm hoping you are right that it is either the guide pushing, ball, or retainer for the shift lever. I'll be taking it apart in the next couple weeks so we'll see. Thanks for the insight.
original possum
02-16-2008 18:12:49
The ball thru which the shift lever passes in the tranny cover may have the spring loose or the swollen part on the end of the shifter may be worn. The worst possible cause would be a spun out front bearing that has allowed slop in the tranny's bottom shaft (which puts the shift forks in a different position). To check any of this you pull the tranny cover. Hook a bent welding rod under the bottom shaft and you should see no significant movement if the bearing is good. Do you have the shifter stick guide that fastens under the seat?
