BLOCK HEATER 4-53 DET.
JACK RAYBURN
02-16-2008 17:35:24
HAS ANY ONE INSTALLED A BLOCK HEATER ON A 4-53? IF SO WHERE DID IT PLUMB IN AT? THANKS JACK
jdemaris
02-17-2008 09:51:04
 Re: BLOCK HEATER 4-53 DET. in reply to JACK RAYBURN, 02-16-2008 17:35:24
I've got two 3-53s, both with generic 2000 watt tank heaters. Easy hookup and they work fine.
luapp
02-16-2008 17:58:18
detriots have a little plate with two bolts close to the top of the head oppiset side the water pipe line to water pump. the heater goes in there. no hoses. they work very well. any body that sells detroit parts has them. not hard to find or put in.i think a 500,750,or1000 wat will fit.
Jon Hagen
02-17-2008 10:15:12
 Re: BLOCK HEATER 4-53 DET. in reply to luapp, 02-16-2008 17:58:18
I was able to fit a lower hose heater to my 4-53 Detroit powered 1900 Oliver. An easy uncluttered fit and worked well in -20 weather.
