Allis hd 5 or 6
James E. Hockin
02-19-2008 05:48:45
I am looking at an Allis 5 or 6 crawler loader with Detroit. Tractor in pretty good shape. Want to restore/use. Anybody know how high it will dump over edge of trailer?
ShawnCol
02-19-2008 09:21:01
 Re: Allis hd 5 or 6 in reply to James E. Hocking, 02-19-2008 05:48:45
The operators manual I have for my HD5 loader (Model TS-5 Tractoshovel) has a dimension chart that shows the pivot pin being 9'-2" off the ground. It has several other dimensions that might be useful, if you have a fax let me know the number and I can fax it to you. Shawn
hector gemme
02-19-2008 08:59:26
the hd5 use a DETROIT 271 AND SOME HD7 USE a Detroit 371
jdemaris
02-19-2008 06:00:36
HD6 does not have a Detroit - it has a Buda 344 cubin inch four-stroke engine.
James E. Hocking
02-19-2008 06:32:14
 Re: Allis hd 5 or 6? in reply to jdemaris, 02-19-2008 06:00:36
This loader definitely has a G.M. engine.2 cylinders. The ID plate is unreadable.Could it be an h5 or 6? I read somewhere that G.M. and Allis had a falling out,thus the Buda. jim
jdemaris
02-19-2008 07:06:14
 Re: Allis hd 5 or 6? in reply to James E. Hocking, 02-19-2008 06:32:14
Yes, and the falling out led to the creation of the HD6. The HD6 is basically a repowered HD5 with the Buda four-stroke instead of the Detroit two-stroke.
James E. Hocking
02-19-2008 07:23:31
 Re: Allis hd 5 or 6? in reply to jdemaris, 02-19-2008 07:06:14
jd Any idea about bucket dumping heighth. I guess if needed I can build a pad for heighth. One part of ID plate looks like the word TRACKMOBILE?
jdemaris
02-19-2008 07:50:34
 Re: Allis hd 5 or 6? in reply to James E. Hocking, 02-19-2008 07:23:31
HD5 and HD6 both came with Tractomotive loaders with 1 1/2 yard buckets - but I'll have to dig around a bit and see if I have any lift specs.
