2010 crawler help
jsp17268
02-21-2008 15:18:40
I am looking at a 2010 diesel crawler that does not turn to the right. is this probably a brake issue? and is it a difficult job to replace brakes?
CHinNY
02-22-2008 11:38:56
 Re: 2010 crawler help in reply to jsp17268, 02-21-2008 15:18:40
I have any parts you need for that machine including the gauge to set the finger with. Email me for my web site with contact info.
nnaatz
02-22-2008 06:37:44
they are a pain, while your in there replace every thing seals, clutches brake band ect...and make sure you get the gage to set the pressure plate and it probally be the last time you take it apart
jdemaris
02-22-2008 06:22:24
Yes it is difficult for a number of reasons. It's possible it just needs an adjustment. But, usually it does not work that way with any crawler with dry clutches and brakes. You pull it apart for one little problem, and once inside, find many - such as rust, stuck, or oil-contaminated clutches, brake bands, etc. Also often find many stripped or broken bolts along the way. When you pull apart a crawler for any problem, it's often hard trying to judge how far to go, or when to stop fixing and replacing. When the 2010s got taken over by the 450 series, the steering clutches and brakes got much easier to work on.
U9U9 CAT
02-23-2008 20:33:54
 Re: 2010 crawler help in reply to jdemaris, 02-22-2008 06:22:24
you sure said it amen
jonjon
02-21-2008 16:30:02
www.jdcrawlers.com Lavoy can tell you all you want to know about this machine.
