D6B Roller Frame calling Old Magnet
U9U9 CAT
02-23-2008 20:56:19
Got her together today.. Everything is straight true, plume square and right to the letter. Now just some maintance thats long overdue.
I pulled the batterys out and got them on charge now. Hopefully I'll get out there tomarrow and change the oil, and change the fillters, I have been accumatlating parts for awhile, oil and filters ,shifter nobes ect I'm a machinst I had also made the cylinders that house the oil fillters one was leaking, rusted out. Question does the track adjusters, grease sert just a regular grease sert? Thanks for your help Magnet
Old Magnet
02-23-2008 22:57:51
 Re: D6B Roller Frame calling Old Magnet in reply to U9U9 CAT, 02-23-2008 20:56:19
Good for you...was kinda wondering if it would ever come together.
If it is the standard screw adjuster it just uses a standard zerk and any ol grease will do. If it has the hydraulic adjusters they use a special check ball fitting along with a standard grease zerk and uses ball and roller bearing grease.
