part numbers needed D6B 44A
U9U9 CAT
02-24-2008 18:43:02
Still having trouble with track adjuster grease sert, I would like to get a new one, but I need a part number for it. Also do they have a kit for the fuel sedament bowl sceen its rotten I would need a part number for the fuel sedament bass sceen filter, gasket and the nut that holds the bale to tighten the bowl. Thanks in advance Mike
Alwaysbusted6
02-25-2008 19:13:30
 Re: part numbers needed D6B 44A in reply to U9U9 CAT, 02-24-2008 18:43:02
Mike, good to hear that you are close to getting your dozer back up and running. give me a call and so I can stop by to take a look. ted
U9U9 CAT
02-26-2008 00:41:25
 Re: part numbers needed D6B 44A in reply to Alwaysbusted6, 02-25-2008 19:13:30
Yep, It's been an up hill battle. It takes so long when you have so many little problems. But I learned alot, thats something. Mikes dozer, has seen it all, I think I'm on solid gound now with her.
Old Magnet
02-24-2008 21:07:48
Ya didn't tell me what type track adjuster it is so I'm going to assume it is the hydraulic adjuster type. To do both sides takes:
2-valves #5M6707
4-washers #5M6708
2-fittings(zerks) #6H9049
2-ball check assem. #5M6709
Fuel filter:
element #7B4457
bail assembly #9B4512 (includes nut)
gasket #9B4519
When am I going to see smoke?????
U9U9 CAT
02-25-2008 00:31:58
 Re: part numbers needed D6B 44A in reply to Old Magnet, 02-24-2008 21:07:48
I moved her around today, just have some minor adjustments to do, she cranked right up I've been having alot of luck lately. Thanks for your help I'll send some pictures, one of these days.
