Allis HD4 6 way blade cylinder
Justin1660
02-28-2008 17:34:14
Any one know where I can find a hydraulic cylinder for my hd4? It is the one that angles the blade. Thanks
jdemaris
02-29-2008 09:09:27
 Re: Allis HD4 6 way blade cylinder in reply to Justin1660, 02-28-2008 17:34:14
Angles or tilts? Either way, they are availble all over new, often for less than $100. Used often less then $60.
HD4 cylinder that tilts the blade is 3 1/2" bore by 8" stroke with 1 1/4" OD pins. Such as:
Link
ydraulic new 3” X 8” $135
Link
e=hydraulic used 3 1/2” X 8” $55
Link
ame=hydraulic new 3 1/2” X 8” $95
Justin1660
02-29-2008 15:36:36
 Re: Allis HD4 6 way blade cylinder in reply to jdemaris, 02-29-2008 09:09:27
It is for the angle.
Thanks,
Justin
Rays
02-29-2008 08:00:15
I donot have a good used cylinder at this time but I can rebuild your old cylinder. Let me know if interested. Thanks Rays
Justin1660
04-03-2008 09:07:12
 Re: Allis HD4 6 way blade cylinder in reply to Rays, 02-29-2008 08:00:15
The rod is bent and the tube is gouged. Do you know where I could find a replacement?
Rays
04-03-2008 12:03:54
 Re: Allis HD4 6 way blade cylinder in reply to Justin1660, 04-03-2008 09:07:12
Justin, I can replace the rod with a new shaft, can also replace the tube with a new one, and install a packing kit. I donot know were you would find a replacement. Let me know if I can help, Thanks, Rays
