Case 580B Shuttle valve
Big 3010
02-29-2008 15:17:30
I have a 1974 Case 580B diesel with the power shuttle transmission. To move the tractor in gear, it has gotten to the point that I have to depress the shuttle pedal repeatedly several times in a row to get the tractor moving. I also have to keep the shuttle pedal pushed in about a half inch to keep the transmission pressure in the normal range while driving forward. I occasionally will lose reverse after the tractor has been worked for a couple of hours.The transmission pulls good otherwise. I'm thinking that I probably need to rebuild the transmission shuttle valve. I have changed my transmission and hydraulic filters as well as the oil but to no avail. One mechanic at the case dealership told me to check a small round filter on the side of the torque converter housing which can plug up occasionally but I have not seen any such filter anywhere on the housing. The only transmission filter on the tractor is in front of the radiator to the left of the hydraulic pump. The case dealer also told me that the shuttle valve spools are no longer available but I can still get all the seals.
Anybody had this same problem?
Any suggestions?
