Buy the kit right from this website -their parts are fine and have good prices. Their parts catalogs are awful and have many errors - but their parts and prices are fine. Just call to verify before ordering. If you have an old block with no grooves cut into it - make sure you order the sleeves that take 3 seal rings ON the sleeve. The sleeve will have three grooves machined into it. If your block is newer and has two grooves IN the block - then you order the newer sleeeves that only have one seal ON the sleeve and take two more in the block. The kit for early 219 engines that comes with the special three-seal sleeves I believe is this - and note it states "o-rings on liner." Engine Major Overhaul Kit - Made by TISCO. For 2520, 440A with SN 275483> 4.219 Diesel, 300 series, O-Rings on liner, 4 cylinder, 4.02" bore, 1.185" pin. Engine Major Overhaul Kit includes: Piston Liner kit, Main Bearings set, Crank Seals, Connecting Rod BearingsBushingsBolts set, Cam Bushing, Gasket Overhaul set. When ordering, specify in comments Main Bearing Size of Standard, .010, .020 or.030, Thrust Bearing Size of Standard, .010, .020 or.030, Connecting Rod Bearing Size of Standard, .010, .020, or.030. Camshaft Bushing of out dia.020 OS or in dia.020 OS. (Part No: OK1430)
