Case 530 w/ #31 loader
Dennis/Ohio
03-04-2008 02:50:41
Hello,
My loader drops much too fast. One of the lift cylinders had a elbow at the bottom that had a rubber rod glued inside the fitting (rubber rod looked damaged like it was overheated with a torch etc.). I drilled it out so I could use it like a standard fitting. The other side already had a standard fitting. I have the Case parts & owners manuals. It doesn"t mention this anywhere. Operators manual states: Never drop a loaded bucket too fast and stop it. The control is so sensitive, its hard not to do it. Suggestions?
Old Magnet
03-04-2008 08:56:59
 Re: Case 530 w/ #31 loader in reply to Dennis/Ohio, 03-04-2008 02:50:41
My 530CK uses an orifice plate that is seated under the valve to hose adapter for the line going to the boom cylinder. Seems you could go that route with a little experimenting on orifice size.
Dennis/Ohio
03-04-2008 09:41:39
 Re: Case 530 w/ #31 loader in reply to Old Magnet, 03-04-2008 08:56:59
Old Magnet & all
Not to get too lengthy. I"m wondering if anybody has seen a fitting (with rubber inside, rubber round stock laced through the fitting) like this? Also I think it was designed to hold the bucket up if a hose blew? Thanks, Dennis....
Old Magnet
03-04-2008 17:45:40
 Re: Case 530 w/ #31 loader in reply to Dennis/Ohio, 03-04-2008 09:41:39
No, never have seen a hydraulic orifice or flow restrictor made out of rubber. Seems like somebody's make do to me.
