HELP! Is Universal ATF OK for a CAT D3B?
KS
01-24-2002 07:10:45
I inherited this bulldozer, the guy at Tractor Supply said that this Universal Tranny Fluid (equivalent to dextron III and mercon) was Ok for the transmission (it does say OK for caterpillar T-10 on the bottle), now someone else says it isn't..is it or not? HELP before I ruin it!
thanks,
Kerry
Jim in SC
01-24-2002 20:22:00
 Re: HELP! Is Universal ATF OK for a CAT D3B? in reply to KS, 01-24-2002 07:10:45
I work at a Cat Dealership. I wouldn't recommend that oil. You are better off with a heavy duty transmission oil with the grade dependent on your ambient temperature. Under no circumstances should you use an engine oil...it will damage the clutches. A few $$ more for a good oil can save some major $$$ in a repair bill!!
