more 2010 help
jsp17268
03-09-2008 09:52:29
help I need tips for removing the final drive housing on my 2010 track loader.... I cant get the track carrier to slide like the service manual says.....Any tips on how to get the final drive mounting studs to clear the housing???? I though about welding the nuts onto the studs and try to temove the studs??? or taking the cross bar piece off of the final drive housing??? and ideas would be greatly appreciated
PL
03-15-2008 05:38:57
 Re: more 2010 help in reply to jsp17268, 03-09-2008 09:52:29
Hi, this is how I got my track frame to move. I drilled a hole in the housing and soaked for days while heating with torch and a big hammer.If you notice on a lot of 2010 dozers, they cut the back of the track frame to get the finals off then weld them back on.PL
2010owner
03-13-2008 15:56:51
I wonder what it is about bucket loaders...
I bought one for parts for my bulldozer and had the same problem getting the track frame to slide over so I could remove the final. It's been 8 years, but as I recall, it took a lot of heat on the casting that surrounds the shaft, penetrating oil, and a 12 ton jack to get it to move.
On the other hand I've never had a problem sliding the track frame over on my bulldozer. I've had the finals off three times over the last 30 years.
B.
pdmechanical
03-09-2008 10:14:06
I believe you have to jack up the rear of the tractor allowing the track frames to hang down. This should provide enough clearance to remove final.
