d450 crawler
Stan Jerry
03-20-2008 11:46:32
My friend has a Case D450 crawler whichworks fine when the outside temperature is above 0 degrees celcius. But when the temperature drops below 0 degrees and colder the drive does not work.Seems it hibernates in cold weather.Any Ideas as to what is going on.
thanks Stan
John Van Valkenburgh
03-21-2008 07:31:37
 Re: d450 crawler in reply to Stan Jerry, 03-20-2008 11:46:32
I'd guess that the hydraulic (drive) oil is contaminated with water. I'd change out the oil. Be sure to clean the screen filter that sits on the bulkhead and has the 2 inch diameter hose that feeds the charge pump.
Are the gauges working? Do they show pressure?
Best of luck,
John
1968 Case 450
