Cat 951c / 3304 engine
PeteChuberko
03-23-2008 11:44:03
My hilift sat for 3 or 4 years since it was last run. I have new batteries and use a 24v booster pack. It turns over well but just won"t fire, even on ether. I did loosen both valves on #3 cylinder and checked the others and all are free. I just can"t get it to fire. I get some gray smoke and a little put here and there but nothing more. Not sure where to go from here.
AJ.
03-23-2008 12:45:42
 Re: Cat 951c / 3304 engine in reply to PeteChuberko, 03-23-2008 11:44:03
Have you checked the air trunking does not have a neast in it! loosen an injector pipe and spin the engine over and see if its injecting fuel,if not the fuel is still shut off that machine would have the sleeve metering fuel system on it and if the throttle control was left in the stop position when it was parked it is a fair bet to say it still is even though you moved the lever,you will have to take off the cover and free it.
AJ
jonjon
03-23-2008 18:05:17
 Re: Cat 951c / 3304 engine in reply to AJ., 03-23-2008 12:45:42
AJ good to see you made it back to the yt side.
