Yes, that be me, good memory Bob, was my 1st day on the job with this company after acing the tryout on a saturday, it happened that day and twice after, it just had an overhaul, sure ran great, but I did make sure to clear my name, I figured I would be fired for it as they would think I was abusing the machine, but that was not the case, never forgot that problem, just some of the bits and pieces I remember from sitting in the seat. It was funny, they liked me because I'd run anything no matter how old or what condition whereas others would complain, I never got laid off in the winter though, many of the complainers did. Yes, the frame being tweaked, motor mounted on frame, sure makes sense, must really have to hammer a tractor to do that. I'll have to make note of that and the loose mounts etc. mine was really vibrating, after taking a look around, belly pan bolts and all kinds of things loosening up from that thing going bad, kind of why I thought to mention it for DGH to see if there was a cause. They certainly are strong those things, it took awhile for them to fail, that clutch was literally flapping around in there, rubbbing on the bellhousing, luckily it did not take anything out, even the pony pinion was ok after. I found a complete clutch assembly in decent condition so at least I have a good driven plate the other a machinist would have to repair, but I need to re-line the friction material, check the pilot bearing on it, would hope not to have to deal with it again, as the tractor will never see any heavy use. One of those things that I've still not finished, and it's not that big of a deal, been turning both motors over by hand 1x a month for now though, don't need this one to seize up.
