Cat D3B Hydraulic Fluid
Terry Bowen
03-30-2008 21:29:47
I have an old Cat D3B and the front blade does not always want to raise when I need it to. It kind of bumps up when it does raise. Is there any way to bleed the lines to remove air?
What is a good Hydraulic Fluid to use? I can"t find 10W that the owners manual recommends.
Terry Bowen
03-31-2008 20:34:41
 Re: Cat D3B Hydraulic Fluid in reply to Terry Bowen, 03-30-2008 21:29:47
I appreciate all the responses I have received. Today I noticed on the left front arm for the blade a round piece of metal. It looks like a set of encased bearings. My owners manual and parts book doesn't show any of these parts. It looks like these bearings should be seated inside the valve casing where the arm extends and retracts. I could be loosing fluid and pressure at this part. I guess I'll have to search for information on blade repair. I'm not sure what the name for the valve on the arms is.
Any idea where I can get pictures and repair info for my problem?
Penn
03-31-2008 15:38:03
The page for the D3B from my Shell book.
P
135 Fan
03-31-2008 09:51:17
Check your hyd. fluid level. It sounds like it could be low. Dave
midlam
03-31-2008 08:58:06
can use the modern multi-weight tractor trans/hydraulic lube.
Bob/Ont
03-31-2008 05:50:31
You can use the same oil in the hyd as you use in the engine. Powershift Trans needs TDTO4 or equivilent.
Later Bob
Gary B Down Under
03-31-2008 00:39:49
Terry, depending on which part of the country you are in, if it is cold than you best to stick with the 10w oil, but if you are in temps above say 25dec cel you can always use 430 (30w) with out any problems. as for removing air from the cylinders the most practical way is to make sure you have enough fluid in the hyd tank, and just work the implement up and down until it stops jurking. best of luk Gary.
