D6B cable winch getting hot
U9 U9 Cat
04-01-2008 00:44:44
The winch housing is pretty hot, works good.. But so hot you can't touch it. Is this normal? Its Full of oil, I have a , pin on rake, on the front also, now it leaks a little oil looks like its throwing alittle grease between the drums but not enought to have to add. Thanks
Bob/Ont
04-01-2008 07:33:05
 Re: D6B cable winch getting hot in reply to U9 U9 Cat, 04-01-2008 00:44:44
I think you have your clutch adjustment too tight and the plates are dragging all the time. Adjust it so it takes more lever movement to lift blade and see if that helps.
Later Bob
U9 U9 Cat
04-01-2008 17:19:48
 Re: D6B cable winch getting hot in reply to Bob/Ont, 04-01-2008 07:33:05
Thanks Just about got the bugs worked out shes doing good
