941 Tilt Cylinder brackets
RLFox
04-02-2008 19:18:31
I noticed that when my bucket is all the way down, that the brackets that tilt cylinder butts into which then connect to the frame are pretty loose/sloppy, meaning when i shake them they slide back and forth on the pins real easy. Is there something I'm missing in my maint that could tighten those up or prevent them from getting so sloppy?
135 Fan
04-02-2008 22:21:13
 Re: 941 Tilt Cylinder brackets in reply to RLFox, 04-02-2008 19:18:31
They are either worn out and need new bushings or they're just greased and maintained so they slide a little. Maybe a little worn and a combination of both. My 931B they slide around with no force on them. Dave
RLFox
04-03-2008 05:14:29
 Re: 941 Tilt Cylinder brackets in reply to 135 Fan, 04-02-2008 22:21:13
I think you're right, greased up, and worn. Guess I'll go ahead and finish what I'm doing before I worry about it much. Thanks Dave!
Bob/Ont
04-03-2008 06:05:49
 Re: 941 Tilt Cylinder brackets in reply to RLFox, 04-03-2008 05:14:29
To fix them you need new pins, weld up the bores. Then tack weld them together in pairs that work together and have a machine shop rebore them to fit the pins.
Later Bob
RLFox
04-03-2008 18:13:47
 Re: 941 Tilt Cylinder brackets in reply to Bob/Ont, 04-03-2008 06:05:49
Thanks Bob, How crucial do you think it is that they be fixed before more use? I'd like to use soon, but don't want to harm it or me in the process..
Bob/Ont
04-04-2008 17:17:04
 Re: 941 Tilt Cylinder brackets in reply to RLFox, 04-03-2008 18:13:47
Use it cautiously at first. It should still be okay.
Later Bob
