D8 1H Fuel in crankcase
DGH
04-06-2008 18:07:13
I am getting lots of fuel into the crankcase. The oil in the injector pump and in the accessory drive ( above fuel transfer pump ) is ok. Any ideas on how it is getting in??
Old Magnet
04-07-2008 19:20:04
 Re: D8 1H Fuel in crankcase in reply to DGH, 04-06-2008 18:07:13
Hi DGH,
What your describing sounds like the front mount LeTourneau Power Control model DN8.
Dandy Dave,
Hi, yes, I still make the rounds at ACMOC but its getting a little tiresome with the same old topics and such a klunky bulletin board.
DGH
04-07-2008 19:26:52
 Re: D8 1H Fuel in crankcase in reply to Old Magnet, 04-07-2008 19:20:04
Thanks for all your help Old Magnet. I will see what I can find on a DN8
Dandy Dave
04-07-2008 03:40:39
Say Old Magnet. Good to see your still out there. :D I had this same problem with a D2 a number of years ago and the solution was the same as yours.
Do you still go the the Cat website? I haven't been there in a while. Dandy Dave!
Old Magnet
04-06-2008 20:02:47
Check the "O" ring seal,pt #6B4967 that seals the fuel delivery passage at the joint between the filter housing and the injection pump. When these dry out/shrink they let fuel leak down into the crankcase. The same seal is also used at the other end of the passage and should be changed at the same time.
DGH
04-07-2008 18:19:45
 Re: D8 1H Fuel in crankcase in reply to Old Magnet, 04-06-2008 20:02:47
I found the seal in my parts book and made a list of the gaskets I will need. Will call the Cat dealer tomorrow, hope it is all still available. That is most likely the reason why I need to bleed the air out the fuel system to start it after it has sat a while. On another topic, I have a front mount cable control, cable comes straight up out of the top not at and angle like a Cat no 24. Any idea what make it might be. There is a plate the comes up the front from the bottom that clamps a shaft out the front with two flats spots. The shaft adjusts the rate of pick up.
