thomas-450 charge pump
tmoore45acp
04-07-2008 14:00:47
put new seals and o rings in pump and it is now pumping-YEAAAAA -thanks to all who offered advice-i will dance at your next wedding if you are that dumb-thomas
tmoore45acp
04-07-2008 16:54:12
 Re: thomas-450 charge pump in reply to tmoore45acp, 04-07-2008 14:00:47
i noticed that pump turned freely with no resistance before reseal-after i put new o rings and new seal it took considerable force to turn pump.
thomas reed
04-09-2008 06:08:38
 Re: thomas-450 charge pump in reply to tmoore45acp, 04-07-2008 16:54:12
tmoore 45 acp did your pump shaft have any wear where the seal run? My shaft had groove where the seal run that might be my trouble and I can not find the gears any where. I might be able to fill the groove with something its just the with of the seal lip. I am glad you are going again. Thomas
tmoore45acp
04-09-2008 07:01:43
 Re: thomas-450 charge pump in reply to thomas reed, 04-09-2008 06:08:38
yes it did-did you put those o-rings in behind front bearings
thomas reed
04-11-2008 05:15:06
 Re: thomas-450 charge pump in reply to tmoore45acp, 04-09-2008 07:01:43
tmoore yes I put the orings behind the front bearings. I have not tryed it again since last post may in a day or two. Thanks Thomas
