looking for dozer JD 450C.Case 450,
rbbrown
04-09-2008 06:21:27
I am looking for dozer, wet clutches 14000 to 15000 lbs don't care if its need some work,'as long its priced reasonable. Any body out there looking to upgrade or just have one forsale, contack me.I live in Tioga Center NY 13827.If you know where I should look or might know of one please drop me a line.I would really be grateful,you can contack me here or catlinspace@yahoo.com .
rbbrown
04-12-2008 07:48:52
 Re: looking for dozer JD 450C.Case 450, in reply to Lanse, 04-09-2008 06:21:27
I don't know of any major 450 tranny problems.There is a problem with the 550's uptill the model G.The local dealer told me to stay away from those.He said the 450C was a good investment.After market parts are cheap.I looked at in all the trader sites,Ebay ,Craigs list and local yards have not seen one with with bad tranny.Have seen at least 6 D3's with bad tranny's, plus seen 4 other D3's in yards machines with missing tranneys.I heard they may of fixed it with the C model.Seen a couple JD550's with tranny problem also.If the owner never changed or checked fluid's any tranny might go bad.But the older D3's really stood out.Some one here expalined how to tell the difference between the Cats trans type but can not seem to find it.
rbbrown
04-12-2008 07:31:08
 Re: looking for dozer JD 450C.Case 450, in reply to joes13, 04-09-2008 06:21:27
135 Fan said: (quoted from post at 01:36:25 04/12/08) Age. B and then C are upgraded machines. Dave
I guess that.I ment whats the difference between them. JD 450C has wet clutches and turbo engines compared to a B.I know the Case does not have steering cltches,but what improvement was made.More HP?
rbbrown
04-10-2008 11:55:15
 Re: looking for dozer JD 450C.Case 450, in reply to kc5gxc, 04-09-2008 06:21:27
Whats the difference in the Case 450 ,450B or 450C
135 Fan
04-11-2008 17:36:25
 Re: looking for dozer JD 450C.Case 450, in reply to rbbrown, 04-10-2008 11:55:15
rbbrown
04-10-2008 11:53:19
 Re: looking for dozer JD 450C.Case 450, in reply to Bob Blue, 04-09-2008 06:21:27
PD Mechanical said: (quoted from post at 21:21:41 04/09/08) I have a very nice 450C John Deere for sale in Syracuse area. Contact me directly for more information. sdyger@twcny.rr.com
Do you still have the machine?I tried your email no reply
PD Mechanical
04-09-2008 13:21:41
 Re: looking for dozer JD 450C.Case 450, in reply to rbbrown, 04-09-2008 06:21:27
135 Fan
04-09-2008 11:37:28
Check out machinery trader. Apparently JD 450's have major trans. issues. Later model Cat D3's had optional wet brakes but the older dry brakes work very well when adjusted right. Some people prefer dry brakes. I have a dry brake 931B Cat. It has a 3 forward, 1 reverse transmission. A 3 F, 3 R trans. is also used. They both work very well. There is no need for high speed reverse. Cat does have very good parts availability and manuals. A lot of people prefer Case over JD. Dave
tmoore45acp
04-09-2008 12:50:14
 Re: looking for dozer JD 450C.Case 450, in reply to 135 Fan, 04-09-2008 11:37:28
if you buy a case dozer make sure you get the new style 6 way blade-the c-frame is inside the track frames-the old style parts are not available any where(c-frame on outside track frame)already learned the hard way on that. thomas
Robert from Vermont
04-17-2008 14:13:31
 Re: looking for dozer JD 450C.Case 450, in reply to tmoore45acp, 04-09-2008 12:50:14
Have a 450 c, starts fine. Just realized that it would not move. Found no transmission fluid. Looked under the trans. Found a little hole next to the trans drain plug. Fluid was leaking through the little hole. Why?
