AC HD7G Track Loader
JsAC
04-15-2008 05:35:37
I have a Hd7g track loader that was running great until last fall. I went to store it for the winter and could barley get it to drive. So I parked it for the winter. Tried messing with it this spring....it fires right up, it moved back and forth a little but now it seems to be froze. The motor will still run fine but I just can't get it to move. I don't have a book for it so any help would greatly be appreciated! Thanks!
hector gemme
04-15-2008 08:52:32
 Re: AC HD7G Track Loader in reply to JsAC, 04-15-2008 05:35:37
You SHOULD CHECK THE TRANSMISSION OIL LEVEL AND FILTER AND STREANER.
gemdozer@hotmail.com
JsAC
04-20-2008 15:07:37
 Re: AC HD7G Track Loader in reply to hector gemme, 04-15-2008 08:52:32
I changed the fluid and filter and checked screen. Screen seamed clear. I pulled transmission oil pump and tore it apart. Everything looks okay. I bench tested it with a drill and I got it to pump oil through. Even though it pumped oil could it still be weak enough not to pump from the machine? I'm pretty much at a loss...any info would greatly be appreciated.
Thanks!
