2010c diesel water temp
jsp17268
04-16-2008 18:46:42
I am wondering what the normal water temp is? I replaced the factory gauge with a new one and while pushing trees over the temp got up to 210 while pushing hard and would settle back to 190 while not working hard. do i need to worry about those temps?thank you
2010owner
04-18-2008 19:35:21
 Re: 2010c diesel water temp in reply to jsp17268, 04-16-2008 18:46:42
Check the water temperature at the radiator with a candy thermometer to make sure your gauge is reading correctly.
Mine used to heat up like yours. I had to pull the engine guards off to get more air and occasionally pour water over the radiator.
I pulled the radiator and had it rodded out. The crawler runs at 180 (thermostat setting) all day long, summer and winter.
Keep 50% antifreeze in it (raises the boiling point to about 230)and be mindful of the temperature when working the crawler; until you can get the radiator serviced.
