D6B streering clutch
U9 U9 Cat
04-18-2008 09:01:00
My left streering clutch is way harder to pull back and it doesn't work to well, whats the first thing I should adj. or check out Also, my winch its a 25 has a hole, "looks like a place to grease" on the opposit side of the oil fill in about the same location. Looks like a bearing plate retaner that has a place for a grease sert but no threads? Thanks she's MakIn Smoke..
tiresntracks
04-18-2008 11:25:11
 Re: D6B streering clutch in reply to U9 U9 Cat, 04-18-2008 09:01:00
I would guess that your right steering clutch lever isn't returning all the way, so its still holding the right control valve on the steering clutch booster part way open. When you pull the left one, part of the oil is still going to the right one and your not getting enough pressure to the left one to make it release easily. I would make sure that there isn't any dirt, sticks, rocks, deck plates, etc. binding up the right steering clutch linkage or lever.
As for the #25 cable control, I don't remember a grease fitting there, but someone who knows more about them than I do will have to answer that question.
U9 U9 Cat
04-18-2008 22:57:26
 Re: D6B streering clutch in reply to tiresntracks, 04-18-2008 11:25:11
Thanks I'm deep in the brush thick as hair, that might be it ,THe streering as leaks oil I ad every couple days or so.
