Deutz diesel quits
Glenn4444
04-20-2008 02:49:56
Any help would be greatly appreciated..... ..The Deutz f4m1008 engine on my mini-excavator will start fine and it will run for about 5 minutes and then starts sputtering for 15 - 20 seconds or so and then it konks out. I can restart it again, after a few minutes. Then, after a shorter 2 minutes of running, it konks out again. I can do this ten times in a row if I wanted to and it does the same thing, run 2 minutes then quit.
The fuel cap was removed to check if it was a vaccuum problem and that didn"t help. There are no fuel line obstructions. I replaced the fuel filter and found that one of the stems on the fuel pump (I assume it is the pump on top of engine) was loose. I was happy thinking that I had found the problem, but no such luck. Anyways, the radiator is full, as is the oil. I added additional conditioner as well as anti-freeze in case of moisture. Other than that, I am dumbfounded.
Thank you in advance.
2x4
04-22-2008 00:26:14
 Re: Deutz diesel quits in reply to Glenn4444, 04-20-2008 02:49:56
its a fuel supply problem. Look for hidden in-line plastic filters clogged with black gook or filter screen inside fuel pump with rubber grindings from inside fuel lines.
W R
04-20-2008 03:14:05
Check fuel strainers ,filter,and fuel lines etc.
